I configured the greyscale image in Luban and started the run to engrave on a wood block. It did the first about one fourth and then all else was blank. I let it run to the end and then restarted to see if that was some fluke but it did the same thing. I noticed that Luban wasn’t set for fixed strength so I set it to fixed strength at 80% and it is performing as expected. Simple fix but not sure why it didn’t continue at sufficient intensity to engrave the image without being set to fixed strength.
What file type? Settings for grayscale? for Luban. I keep getting basic black white output.
You can use basically any picture file types, such as svg, png, jpg, jpeg, bmp, and dxf. There is no correct settings for greyscale. You need to play with the settings to see what works best for you. Here is a rough guide to help you get started.
I’m still having issues with it not showing up blank.
Have you tried the latest version?
I’m in the latest firmwi
I mean snapmaker luban.
Like snapmaker js (version 2.7) and luban I’m on 3.8. Something
could you post a screenshot of your luban workspace please?
you use luban to run the job I presume
oh wait I think I know what’s going on, you are using Line mode, right?
I was using the dot mode and i switched to the line mode but neither seem to work.
It won’t let me upload the picture of my workspace
ok, try this, dot mode, density 10, speed 3000, dwell 1, power 30.
Make sure focal length is ok 24/25ish.
Going to bed now, good luck, hope to read some succes in the morning.
Don’t forget to use proper material height.
And if prntscn button don’t work for you, use phone to make pictures
TTFN
