June 26, 2023, v4.8.1
System Requirements
  • macOS >= 11, for legacy macOS 10 versions (Catalina, Mojave, High Sierra), please upgrade to at least macOS 11
  • Windows x64
  • Linux 64 bits distros
What’s Changed
Improvements
  • Added SM2.0 Quick Swap Kit detection
  • Added J1s machine and adjusted parameters for J1/J1s
  • Added Quick clear mesh painting in object list
  • Added Dual material interlock parameter
  • Optimized mesh painting slicing speed & interaction
Bug Fixes
  • Fixed the issue where default presets could not be selected for certain material types.
  • Fixed the issue where mesh painting slicing results were incorrect when the model was assigned as a right extruder.
  • Fixed the issue with some initial layer parameters being in the wrong directory.
  • Fixed the issue with abnormal saving of certain print configuration parameters.
  • Fixed the problem of some models failing to slice.
  • Fixed the issue where objects could not be selected and deleted in Laser and CNC modes.
  • Fixed the problem of Prime Tower not being automatically generated in certain cases.
  • Fixed the software crash issue caused by using the pen tool.
  • Fixed the issue where coloring STL files was not saved in the project file.
  • Fixed the issue where 3D printing slicing would generate extra skins.
  • Fixed the problem of J1 Console not being available.
  • Fixed the issue of Laser and CNC toolpaths getting stuck.
  • Fixed the issue where 3D Gizmos would disappear after use.
  • Fixed the problem of confusing material type content.
  • Fixed the issue where Laser toolpaths could not be generated on Linux systems.
Full Changelog: v4.8.1
Download links
We provide Snapmaker Luban for different platforms:
  • macOS x64/ARM64
  • Windows x64
  • Linux
Please refer to our Github releases page to download.
Feedbacks
For the full user manual for Snapmaker Luban 4.0 and later, please checkout Snapmaker Luban 4.0 User Manual .
