Sep 20, 2022: v4.4.0
Brief changelog:
New features
- Featrue: Added material parameters and printing parameters up to 290+
- New quick parameter setting interface
- Enhanced parameter management interface
- Variety of parameter display modes
- Detailed parameter explanation
- Feature: Added 3MF, AMF support in 3D printing/Laser/CNC editor
- Feature: Added Model Repair and Model Simplification
- Feature: Added Simulation Preview with volume in 3D printing editor
- Takes more time to generate the preview
- Simulation preview will not be displayed when insufficient memory is detected, but G-code can still be exported
- Feature: Quick preview of some parameters before slicing
- The preview results will be partially different from the slicing results
- Feature: Default print configuration tied to material and nozzle diameter
- Feature: Added workflow to publish releases to Windows Package Manager
Improvements
- Improvement: Optimized the style and interaction of 3D Canvas
- Optimized zoom-in operation and pan operation after zoom-in operation
- Improvement: Supported to use backup mirror of software auto-update when access of github releases is limited
- Improvement: Optimized vector machining paths for Laser and CNC
- Improvement: Set the Auto Connect button in the workspace tab to unchecked by default
Bug fixes
- Fix: Fixed incorrect parsing of SVG with nested text elements
- Fix: Fixed the possible wrong position of using the up and down key shortcuts for objects with rotation in Laser/CNC editor
- Fix: Change the timing of the completion of printing is defined as completion rather than the last G-code sent
- Fix: Fixed extrusionDirection attribute of DXF not being parsed
- Fix: Fixed incorrect parsing of SVG float numbers
- Fix: Fixed the problem that when has moved after paused, printing was not resumed from the position before the move in Laser and CNC
- Etc…
Known issue
- Electron renderer process crashes on power resume. Electron issue
Detailed UI changes and new features can be found on our Blog: What’s new in Snapmaker Luban v4.4.0 - Snapmaker Blog
Download links
Snapmaker Luban for macOS
- Download: snapmaker-luban-4.4.0-mac-x64.dmg
- Download: snapmaker-luban-4.4.0-win-x64.exe
For Linux versions and Windows 32-bit versions, please refer to our Github releases page to download.
Feedbacks
For the full user manual for Snapmaker Luban 4.0 and later, please checkout Snapmaker Luban 4.0 User Manual .
- Email to support@snapmaker.com
- Create issues from Snapmaker/Luban
