Dec 13, 2021: v4.1.1
Brief changelog:
  • Modified default 3D printing profiles for easier first layer adhesion #1310.
  • Improved G-code execution time estimation (3DP, laser, CNC).
  • Added CNC tool profile “Single Flute 3.175mm”.
  • Improved i18n translations (EN and ZH-CN).
  • Added F250 and F350 machine selections.
For Luban v4.1.0-beta.1, please checkout https://github.com/Snapmaker/Luban/releases/tag/v4.1.0-beta.1 as well.
Changelog lists below:
  • Added support for 10W High Power Laser Module, including Auto Focus feature, upgraded Camera Capture feature, and updated Case Library .
  • Added STL to SVG support for laser cutting.
  • Extended pre-defined profiles with recommended parameters for common laser materials.
  • Added “Rotate on Face” on rotation panel with sugguested faces, you can choose placement face based on Overlap Area and Support Volume required.
  • Derived G-code preview from workspace to separated popup window.
  • Added auto Wi-Fi connect and several built-in Macros for querying machine state.
  • Added (brought back) multi-line text and alignment options.
  • Improved text font parsing.
  • Fixed Console unable to copy/paste on macOS.
  • Fixed irregular font ratio and irregular image width/height ratio.
For the full user manual for Snapmaker Luban 4.0 and later, please checkout Snapmaker Luban 4.0 User Manual.
Download links
Snapmaker Luban for macOS
For Linux versions and Windows 32-bit versions, please refer to our Github releases page to download.
