May. 15: v3.5.0
  • Feature: Separate Laser/CNC G-code generation procedure into 2 tabs: Editor and Process (#303)
  • Feature: Add enclosure Add-on support (#305)
  • Feature: Add Ukrainian language support (#331)
  • Improvement: Reduce application size (#290)
  • Improvement: Persist window size and position when closing application (#306)
  • Fix: Fix 3D printing configuration “speed_infill” display issue (#307)
  • Fix: Inactivate “Macro” widget buttons unless serial/Wi-Fi connection is established (#309, #297)
  • Fix: Fix a bug that “lay flat” function doesn’t work on duplicated models (#312)
  • Fix: Fix a bug that Luban switches to G54 coordinate system when using 3D printing (#320)
  • Fix: Fix emergency stop button’s behavior when print via Wi-Fi (#321)
  • Fix: Fix slicing of OBJ files (#323)
  • Fix: Fix 100% fill density does not work (#326)
Snapmaker Luban for macOS
Snapmaker Luban for Windows 32-bit
Snapmaker Luban for Linux 64-bit
Option 1 (recommended)
Option 2
Snapmaker Luban for Linux 32-bit
Option 2
Hint: To start Snapmaker Luban on Linux, you need to:
  • Add your user to group dialout: sudo usermod -aG dialout [your username]
  • Start executable: snapmaker-luban (.deb version) or ./snapmaker-luban (compressed version)
