Where I can find those CNC models?
I konw, that the 3d printing models are on thingverse.
The laser engerave models I don’t need.
So I just need the CNC models, because some of them looks great.
Hi, the CNC editor on Snapmaker Luban software supports the following file types:
*.svg, *.png, *.jpg, *.jpeg, *.bmp, *.dxf, *.stl
Usually, you can start the CNC work with the files in the above type.
If you want to use the CNC carving and do not have a file, you may check on the following link: https://grabcad.com/library. You can find the files by searching ‘CNC carving’.
