Snapmaker 2.0 Shutdown and USB Removal
Just my opinion, but the Snapmaker 2.0 (ex: my A350) really needs a shutdown option from the touchscreen. Shutting it down by the power switch just seems very odd and “overkill” as you can hear various areas just shut off (power disconnecting from motors for example). It also does not appear to cleanly shutdown the touchscreen itself (as evidenced by the USB problem I am going to mention below). Even if this shutdown only affects the touchscreen and cannot do anything for the controller (let alone the power supply) I think this would be a benefit.
On to the USB… Every time I power it off and bring the USB drive to my computer to add gcode files to it, Windows identifies the USB drive as needing repair. So obviously the USB driver is not properly unmounting the USB drive or leaving it in a ready-to-unmount state when it is no longer being accessed. This is NOT a good thing as it causes errors at Windows (and other OSes) that inexperienced users might be worried about, and it could eventually cause degradation of the drive. Having an unmount/eject/remove drive option at the touchscreen could help alleviate this without powering off the Snapmaker (although that only helps in those cases and a clean power down would still be useful).
I am waiting for a replacement controller due to an issue using the power switch to shut off machine. Support has been awesome and friendly about it. I had to shutdown due to auto level issue to prevent crash of module vs bed. Once it turned off, it didn’t turn back on. It doesn’t feel right killing power via a manual switch without controller/system being ready when not absolutely needed to do so. My other Prusia printer stays on 24/7, doesn’t have option for software shutdown, but it’s silent when not in use, and not a noise issue. The loud power supply fan on Snapmaker makes the user want/need to power machine off when not in use. There is power recovery option is listed in spec sheet, so product design may have intended/planned on power being cut without software, but a software option would be nice. Ensure steppers are disabled, heaters off, ect… USB dismount option would also be nice.
Thanks for you advice.
We will add unmount option for USB drives.
As for situations of cutting down power supply, there is no chance for Touchscreen to unmount USB drive.
when do you think you can make the unload USB ?
I see this problem constantly myself, even if the power isn’t turned off. Still waiting for the eject capability. It’s really annoying.
wen do you think you will have the feature ?
When are you planning to include this feature?
I would also like this feature. Now I need to power down to get another file onto the usb. This is still not implemented soon to be two years after initial report? Not fun.
Not really necessary. The SM only reads from usb drives. It’s not like a computer where it could be interrupted while writing to it.
So, no problem removing it (from SM) with power on?
No more than usual. Seems every USB drive shows up in Windows as “needing repair” whether you power off or not - just ignore the Window’s pop up it’s fine.
Feeding a USB stick that was sitting in my A150 for a while to fsck (a common Linux disk checker tool) shows that the Snapmaker left the dirty bit set but didn’t actually damage the file system. So essentially it’s slapping a “broken” sticker on the drive without actually breaking anything. :roll_eyes:
