Hello,
at my first try to use the CNC Modul I broke one of the bits. Can give me someone a Name of good new Bits to engrave whicht the CNC Modul
(Sry for my bad englisch
Hello,
RUKO, Dremel, Proxxon are some of the good ones. Depending on the material you are working on, you also can use cheaper ones
Just remember that the collet that came with the Snapmaker is for 3,175mm. If you want to use different shaft diameters, then you need to buy new collets (you can order a set from amazon for 25€) and you can use up to 6,35mm (according to the tec data).
