Smooth Timelapse Mode with Fixed Printhead Position
Description
With the introduction of the Snapmaker U1, which includes a built-in camera, Snapmaker is entering the space of 3D printers with native timelapse capabilities. This is great to see, but there is an important improvement that would significantly enhance the quality of recorded videos.
Currently, in recorded videos, the printhead appears to glitch or jump around between frames. This breaks the visual effect and makes the timelapse look unstable.
Expected Behavior
Many modern 3D printers offer a smooth timelapse mode where the printhead moves to a fixed, predefined parking position before each photo is taken.
This creates the illusion that the print is growing by itself, with no visible printhead movement. The resulting timelapse is visually clean and professional.
Proposed Solution
Add a firmware-level option for Smooth Timelapse Recording, where:
  • The printer pauses briefly at specific layers.
  • The printhead moves to a consistent parking position.
  • The camera captures a frame.
  • Printing then resumes normally.
I believe timelapse frames are set by the slicer. At least I seem to recall it being in the gcode, then snapped or not based on the printer setting.
It’s feasible to implement in firmware, but may be easier to do at the slicer level either way.
I think it could be done in SnOrca via the “Timelapse G-Code” printer setting. I came here hoping to find someone had already done that and posted it… found this post instead :wink: If I’m right, just need to add g-code to save location, move print head out of the way, take a picture, wipe any accumulated drool from the nozzle, move back to saved location and continue. I’m sure I’m missing something important in there, and I am not familiar with the available variables to simplify this process - but if no one else has taken a stab at it, I guess I’ll probably end up trying to do it myself.
​While this could be managed via G-code, it would require direct camera access or an external setup. In my opinion, a firmware-level solution is more efficient and user friendly. In SnOrca the time-lapse functionality can be set after upload the model on the printer or at the printer itself, there’s no need for additional G-code—the printer handles everything internally. This functionality has to be improved by @User_eb.
How are you guys even viewing your time-lapses? In snOrca, I see a list but nothing happens when I click them. In the phone app I always get some message about the network.
It is just loading very slow. Click start in orca, make a coffee and then it starts for me :clown_face:
I view them by downloading files :slightly_smiling_face:
Printer IP → Configuration → Camera → Download required one.
I would like the smooth time lapse feature as well!
Moved to the (new) Feature Request category.
Just to report: there are mods out there which add a “pusher” to each toolhead, and mount a shutter trigger button for an external camera on the U1 frame. The end-of-layer G-Code is then modified so that the active toolhead is moved to press the button.
Be interested to know how much extra time is added, especially to large prints if the head is moving away then back again to re-start?
I don’t see that as an issue, particularly for multi-head printing, because the toolhead has to be parked anyway, and then when the next toolhead gets picked up it visits the wipe tower.
However, this scenario doesn’t work for prints that use only one nozzle. Nothing gets parked in that case.
Moreover, it would be a good solution to capture the image at the moment the nozzle change occurs. Then everything would be parked and nothing would be standing in the middle of the image. And it wouldn’t cost any extra time.
DSC00371_under10MB
Edited your post, so it says more than nothing like a timelaps video..
Yes this is a great idea, and also fix the camera settings in the firmware so that we can get smooth video
+1 for a firmware-level option.
For comparison while this is open: the moonraker-timelapse plugin used on many Klipper printers already does this with a “park head” setting (configurable park position and dwell time), so its options are a useful reference for what a native U1 setting could expose.
Two details that make a big difference to the final video:
  1. A short dwell after parking, before the frame is captured, so the camera’s auto-exposure settles and frames don’t flicker.
  2. Locking exposure and white balance for the whole print, otherwise the colour shifts as the bed fills up.
A “park every N layers” option would also keep the added print time down on tall single-nozzle prints, which addresses the concern raised above.
