No timelapse even though timelapse is on in slicer
Hi guys
Im new to the snapmaker U1 but not to 3d printers. I use orcaslicer so it can connect to my many machines. I have flipped the timelapse video toggle to on and checked that at the beginning of the gcode orca adds the SET_TIME_LAPSE_CAMERA ENABLE=1 and before layer change theres TIMELAPSE_TAKE_FRAME
if i manually start the job at the printer screen i can select time lapse and it will save correctly but i cant get it to do timelapse if i start from the slicer. I have several printers and i just start all jobs from the computer after they’ve been cleaned. Any way to do time lapse with built in camera from the computer?
I also had this problem and submitted a ticket. Long story short, the problem now seems to be resolved by upgrading to the new 1.6.0 firmware. I installed it as soon as it came out and for the past few days, I have had 100% success making time-lapses.
Clicking the toggle in orca now works.
how do i install 1.6.0? im on 1.5.2 and when i click on it it says i have the latest version
1.6.0 hasn’t been released yet – it is for beta testing, others will have to wait. I guess the release version will be 1.6.1.
The Paxx firmware might have already solved the timelapse issue, I’m not sure.
It should be official released on 8.25 and if you’re interested, you can install the firmware here:
As others have noted, you can download the updated firmware froms:
https://wiki.snapmaker.com/en/snapmaker_u1/firmware/release_notes
Save it to a usb drive and sneaker net it to the machine and do a “local update” from the touch screen.
Good luck
