SM2 power module noise
@MooseJuice agree about tons of other problems and they keep annoying me as well. it would be great if the company just offers some way to track all known major issues with progress in one place, what fixes we should expect in the next firmware update, etc. Clearly a better option than having angry customers venting about the same issues over and over again on this and other forums, spending customer support time, etc.
I can find some things had been mentioned in the firmware github, but there is not much about the hardware and not so many progress updates.
Snapmaker was really good at giving progress updates during the kickstarter period, this was one of the reasons i bought the printer, but now the communication style is a bit disappointing.
Perhaps cc @Edwin
Without question it is, and much of it is because people beat the hell out of them continually so they stopped coming around.
However, edwin was posting all kinds of firmware progress and post processing tools and luban updates yesterday so things are beginning to move a bit.
@MooseJuice could you share the urls with the updates? Can not find anything except the github open source links.
Did the change on my PSU, more info here: https://www.thingiverse.com/make:894545 so quiet now.
Thank you for the thread and information and everything, helped a lot!
If you want to use one of the higher quality Noctua fans + couple of usb power ports for cameras or other accessories, you can use this back plate: Snapmaker 2.0 power supply fan 40x20 upgrade by AliSanjabi - Thingiverse
Thanks so much.
Just a little question. Where do you connect the 2 USB ports? Headed for power?
Could connecting 2 or more accessories to the power supply cause problems?
I mean the power supply is not that powerful and adding 2 USBs can overload the power supply. I read in the forum that the PSU is 320W and the printer consumes 290W.
Thanks :slight_smile:
I just use an extra usb brick. Why take a chance?
You must have some lying around or they’re super cheap on ebay or amazon.
That is a good point, I’m using it for a wbcam that I wanted to turn on and off with the printer. I haven’t had any problems, but it doesn’t hurt to be careful. The fusion file is there, you can always remove the USB holes if you don’t need them.
Hello,
i need a little help.
I have bought a noctua fan and a LM2596. ( used this Snapmaker 2.0 power supply fan 40x20 upgrade by AliSanjabi - Thingiverse)
I have connected the fan to the LM2596 and after to the PSU (See photo) but from the PSU there is no output to 24v. Tested via tester and via noctua fan that doesen’t spin.
The printer work good.
Where can be the problem?
20210208_173508|401x500
V+ and V- to get 24vdc.
the ground symbol is the ac ground.
scooch over 1 terminal and you should have it. you can check the voltage with a meter if you have one too.
Oh thanks you very much… :star_struck:
Hi All, I got A350 yesterday and after power on the fan noise was bothering me. The design the way they packaged and used parts was really nice. I will give credit for 100 but the power supply noise for some reason the designer more focused on cosmetic lighting instead of better air flow. After taking it in part I noticed under the front cover there is while plastic for leds. This thing is blocking almost 90% of air coming in. So what I did is I removed the front white plastic including led strip and disconnected the fan in the back. so far so good. Internal power supply has it’s own fan already but pointing up side. So the air will touch the top before moves sides. I will let you guys know if I ended up with any issue. another thing came in my mind is to use voltage regulator and drop the voltage for back fan incase we want to use it. I am EE I will help snapmaker engineers to improve the design. I like this company.
Andre Abelian
PSU Noise update in progress.
Power supply noise optimization
I came up a solution to snapmaker 2 noisy power supply. here you go!
I just put a better fan on it… worked fine.
But thats cool :smiley:
I wouldnt wana do any permanent change to it in the event something goes bad that will be their excuse for it failing. if i mod it, it needs to be reversible.
I redesigned an adapter that allows a 40x40x20 noctua fan and buck convertor to be mounted inside the original back plate without drilling new holes.
I made yet another backplate for fan mounting.
This time its for a standard 24V DC 5015 radial fan:
@JonathanSwivel does your fan blow the air into the power supply, or does it suck it out the air?
Standard fan on the power supply does suck it out, and the internal fan is placed in that same direction, to create an airflow through the power supply.
Hello @bastiaanslee ,
yes, as it is a radial fan, it blows air INTO the PSU unit.
I am aware that this is the opposite direction the original fan did it.
From how the PSU is bult internally i“ve judged that it should do the job anyway:
  • the original ultra loud 35mm and also my 5015 replacement have the job to create air flow in the outer housing.
  • the smaller fan built into the actual PSU (lets call it inner housing) has the job to take some of that air and flow it over the critical components.
So from that reasoning it think that any fan, which creates air flow in the outer housing does the job OK.
So far, at room temperature, as I have the PSU outside of my printer enclosure, I did not experience any issues.
But as always, its DIY and no guarantees for a particular purporse.
Just wondering did this work with you?
As I understand its a direct fan exchange with no need for a convertor or a new back, correct? Did you need to drill new holes in the back?
Thank you!
