Showcase:
1. Pattern textures
Every pattern spans the full depth you set. All of these are simple untextured meshes (cylinders, boxes, a vase, a sphere), textured only at slice time.
2. Live preview, before slicing
The 3D view displaces the model on the GPU while you drag, before slicing. Above: a 3,000-triangle gargoyle with its UV height map. No high-poly copy is made, so nothing has to load. The Displacement map panel at the top left is there from the start and holds every setting.
Settings are per object. Select an object and the panel edits only that object. With nothing selected, it edits the defaults for every object.
3. Local displacement texture generation using a lightweight SD-Turbo model (893 MB)
In Generate from text…, describe a surface (“tree bark”, “cobblestone pavement”, “woven wicker”) and pick one of four seamless height maps. It runs locally, on your graphics card through Vulkan when it can and on the processor otherwise. On an RTX 3080 Ti the first texture of a session takes about 10 s while the card is prepared, and four more take about 1 s. On the processor, each takes about 5 to 10 s. The model is an optional add-on (about 0.93 GB in all) that the app downloads the first time you use it. Powered by Stability AI (SD-Turbo, quantized to 4-bit), with DeepBump for the normals.
4. Mappings
Box (triplanar), cylindrical, spherical, planar and on the surface, with the same 10 mm hexagons on the same 50 mm sphere. Planar top, planar side and UV (the model’s own texture coordinates) are also available, with rotation and invert. For a part loaded from a GLB, glTF or OBJ file, UV uses that file automatically.
5. Map vs baked mesh
Left: a 512-triangle cylinder (Ø40 × 40 mm) with a PNG as the displacement map. Right: the same PNG baked into a 1.26 M-triangle mesh, the way you would do it in a modelling tool today. Both were sliced with the same U1 profile:
Map, whole surface |
Map, per layer only |
Baked mesh |
| Project size (3MF + PNG) |
0.022 MB |
0.022 MB |
15.1 MB |
| Slice time (median of 3 runs) |
1.78 s |
1.53 s |
4.95 s |
| Estimated print time |
57 min |
52 min |
52 min |
Printed on my U1 (Bambu PLA Matte):
6. A low-poly model and its height map
Two models generated with Tripo (48k and 45k triangles) were decimated to 3,000 triangles. What the decimation removed was then baked into a 16-bit height map along the low-poly surface: about 1 mm deep, 2048 × 2048 px.
Printed on my U1 (the gargoyle, Bambu PLA Matte):
Size and speed: these Tripo models are light to begin with, so here the map costs more than it saves.
| Gargoyle (Tripo) |
Project size |
Slice time |
Est. print |
| 48k-triangle original mesh |
0.65 MB |
9.5 s |
4 h 0 min |
| 3k mesh + map, whole surface |
4.6 MB |
14.5 s |
4 h 21 min |
| 3k mesh + map, per layer only |
4.6 MB |
10.4 s |
3 h 52 min |
| 3k mesh, no map |
0.05 MB |
5.7 s |
3 h 22 min |
7. Game assets: relief from the normal map
The previous section started from a high-poly model. This one starts where game assets do: a low-poly mesh plus texture maps. Poly Haven’s carved wooden plate (CC0) has 2,112 triangles. The zig-zag carving on its rim and the chisel marks in the bowl are not in the mesh at all; they exist only in its 4K normal map. A slicer that reads only the mesh prints a smooth plate.
The fork reads the normal map from the glTF file and turns it into relief: it integrates the normal map into a 16-bit height map (0.9 mm deep on a plate 122 mm across) and prints it through the model’s own UV coordinates. It offers this when you load the model, and it is also on the right-click menu and on the command line (`–relief-from-normal-map`). Nothing was modelled, baked or exported by hand.
| Carved plate, 122 mm |
Slice time |
Est. print |
| mesh only |
8.0 s |
5 h 6 min |
| mesh + its normal map |
30.7 s |
6 h 27 min |
One run each. The 30.7 s includes turning the 4K normal map into the height map. The rim’s underside needs tree supports either way.
A character works the same way. Poly Haven’s gothic statue (CC0) has 27,739 triangles. The mesh carries the pose, the robes and the chain, but the face under the veil, the crown’s ornaments and the edges of the chain links exist only in its normal map. With the relief, they print.
| Gothic statue, 150 mm |
Slice time |
Est. print |
| mesh only |
18.5 s |
7 h 51 min |
49.2 s |
10 h 36 min |
One run each. Here the relief is 2.0 mm deep and covers the whole figure, so it adds about a third to the print time.
8. Test print
Printed on my U1 in Bambu PLA Matte, 0.4 mm nozzle, 0.16 mm layers.
Every pattern reads clearly at 0.4 mm deep, on the walls and on the tops. Noise is the softest of the eight: 20 mm noise at 0.4 mm depth is gentle on the walls.
9. How it works (short version)
- Walls: each wall point is moved along its normal by the texture value at its 3D position, using the chosen mapping. Height = (value − (1 − offset)) × 2 × depth.
- Whole surface: for each layer, steep faces offset the layer outline by depth ÷ sin(slope). Shallow faces (tops, slopes, overhang undersides) add or cut material by tracing the texture over the face’s footprint, and the face on the bed stays flat. Everything after that (walls, skins, overhangs, supports) works on the textured outlines, exactly as if the texture had been modelled.
- Per layer only: each layer’s outline is resampled, and every point moves along the outline’s own outward normal by the texture value at that point. Shallow faces are skipped, so nothing is traced over tops.
- On the surface, cells: sites are placed on the mesh, seeded from a honeycomb along it, and then relaxed. Flat areas get a lattice in their own plane; round parts get rows around the axis, spaced along the profile. A point’s height comes from its 3D distance to the nearest two sites, so the pattern is continuous over every edge.
- On the surface, images and stripes: small patches (about one tile across) are placed over the mesh, each with its own frame: level on walls, carried over from its neighbour on tops. Each patch’s image offset is chained from its neighbours across the surface, so the image runs on from patch to patch, and the patches are blended where they overlap.
- Live preview: each part is drawn as tessellation patches with smooth normals. The GPU subdivides them to about 4 px per segment on screen and moves the new points by the same lookup the slicer uses, including the patterns laid on the surface and UV maps (there each corner carries its texture coordinates, and vertices split along the texture’s seams).
- Text to height map: SD-Turbo draws a seamless colour texture in one step (circular padding, 4-bit weights with the most sensitive 30% at 8-bit, run through stable-diffusion.cpp). DeepBump turns the colour into normals, and the normals are integrated into heights (Frankot–Chellappa) and saved as a 16-bit PNG.
- Normal map to height: the normal map is turned into slopes per texel in mm, high-pass filtered and saved as a 16-bit PNG. The depth comes from the model’s real size.
- Tests: 26 automated test cases cover the feature:
- white pushes out and black pulls in, the offset moves the range as set, and the depth goes past the 1 mm fuzzy skin allows;
- each projection, rotation and invert;
- the patterns tile with no seam;
- cells laid on the surface are evenly spaced on sides and tops, smooth over the rim, and the same wherever the part sits;
- images laid on the surface repeat at the tile width on flat faces and run on around a cylinder;
- whole-surface displacement of walls and tops, with the bed face left flat;
- per layer only, with every mapping: outlines move sideways by the full depth and nothing rises above the top;
- open sheets print at the set width, thin parts are widened, thick ones left alone, and a broken mesh slices the same every time;
- textured OBJ loading, normal map to height map (also on a mesh whose facets were reversed when a project was loaded), refusing compressed glTF, and text to height map.
All 138 fff_print test cases pass. Of the 362 libslic3r test cases, 357 pass; the other 5 are upstream tests marked as skipped or expected to fail.
Docs: the “Displacement map” section of `doc/print_settings/others/others_settings_fuzzy_skin.md` in the branch.
Known limits:
- A flat image can’t wrap a closed shape without a seam or stretching somewhere. On the surface avoids that, but where its patches meet you can see faint doubled lines, most of all on spheres.
- glTF files with compressed geometry (EXT_meshopt / Draco, as current Tripo exports) are refused with a clear message. `scripts/glb_unmeshopt.py` converts meshopt files.
- Open or broken meshes can still slice with gaps. Open surface thickness covers sheets, not every hole.
- Very fine, deep textures add print time.
- With UV maps, the live preview can show thin spikes along the texture’s seams at large depths (around 2 mm on the gargoyle). The slicer itself is not affected.
- Tested on Windows only.
