Would be great to be able to skip some parts of a print at the beginning of the job. I have many multi-object jobs stored on my printers that are usually 14-16 hour in total to completion. There are days when I have 6-8 hours at home before I leave for the rest of the day or I get home with a few hours to print but don’t want to run a full job. So sometimes I start up a job with say 6-10 items on the plate that take 10 hours but only want to print 3 or 4 of those items in about 3-4 hours. As the firmware on the printer starts prepping usually I have to wait several minutes before the skip object feature is available and usually I get distracted doing other things before remembering to come back when it’s already started printing the first few layers of items I don’t want.
Tied to that if the time remaining estimate would re-adjust for skipped items that would help also.
Thank you.
I suspect the skip is made available as soon as it reasonably can be! Just a little patience required – you usually want to check the first layer anyway, right?
This just sounds like laziness to me? You can’t be bothered to alter the objects on the build plate before printing and you can’t be bothered to remember skip items once its started?
Lol true, checking first layer is awesome. I usually run the heated bed calibration every print and I’m getting ready for my day job so as much as I enjoy the art of waiting patiently that’s not always an option. Maybe if I skip the calibration the skip option would be there soon enough.
Trust me, I’m plenty lazy at times there’s no doubt. However, if the code can be adjusted to give this option sooner than later it doesn’t change the entire process for the worse correct? I’m usually headed out or just getting home with a million other things to do than wait 5 or 10 minutes and having several hundred jobs stored on the printers it’s less convenient to send smaller/lower quality jobs to clutter up the interface and storage of the printer.
fwiw the skip menu can’t show before the first object definition hits the gcode stream, during prep there’s nothing to exclude yet lol
I always skip the multi-point levelling, the only reason for it to change is with a change of plate or mechanical adjustment.
Further to that: it is an annoyance (and the subject of a feature request) that it defaults to on for evey print.
I’m with @BowenTech on this. At the moment you select the file you want to (re)print, it would be nice to have the option to adjust (skip) things. It al ready asks what filaments you want to use. A skip button at this moment would be nice.
