I have started to have pretty significant build up of filament on nozzle. On a 4 hour print, it will accumulate and drop 5 or 6 big blobs. Have not lost any prints so far, but is often very unsightly. Of course, I have run through all factory calibrations over again. Always used Cura as a slicer, I have yet to try luban, but maybe that’s next.
Re done factory calibrations
Using ABS
Have adjusted z hop, no difference.
Tried speeds between 60mm/s and 150mm/s, also, not much difference
Any tips would be appreciated.
Edit: paused a print and took this photo. Lots of junk on the nozzle. When this accumulation gets big enough, it will get dragged off onto my model
No popping, it looks like blobs accumulate on the nozzle I think due to the nozzle slightly dragging over the printed model while printing, and when they get big enough, they fall off. I thought Z hop was the solution…
Stock settings. I will check…Now that you mention it, I think we started seeing this when we switched over to black abs. We had been using other color abs and never noted this issue before.
