So, after a long time with the Snapmaker 2.0 A250, I have noticed that I am not using it as much as I wanted. So I am hereby selling it to whom might be interested. I still have all the original boxes, so you can have the same unboxing experience as I had!
I am selling it for 1000€ with bunch of extra things:
- MDF made fully sealed enclosure with integrated socket
- about 600g Pastel blue filament spool
- 2x SM Print sheet (1 new and 1 used)
- Still have the extra print nozzle
- A lots of CNC bits (see picture)
- Self made CAM lever for clamping CNC jobs
- Self made wasteboard, so the original CNC wasteboard is almost as new
- 6x SM Casted acrylic plate
- 2x SM 3mm MDF plate
- 1x SM 1.5mm plywood
- 1x 35x35x3mm plywood
- A bunch of 18mm plywood with different color
Located in the Netherlands, shipping cost is excluded and will be discussed with you upon checking the different courier. Shipping to other EU countries is also possible.
You can check all the pictures and some of my past projects here:
https://bit.ly/3nCgDUm
