Is it possible to include the actual size of a model alongside the percentage setting for scaling models when processing for printing?
Otherwise I don’t know what size they are!
Regards
Graeme
Regards
Graeme
Probably not in Luban.
I think Cura can do that, as well as Simplify3D. I would assume prusaslicer would too.
Edit:
the latest version of luban does have a dimension in the corner of the sheet
this is on a pre-release build.
i dont know if older versions do
they also added manual supports so i happened to fiddle with it a bit to see if it was any good and noticed that just now.
even still, for example simplify3d i can tell it a specific size to print at instead of a percent.
checking cura also allows for this:
which by the way you are going to want to try cura after you are bored of luban, its far superior in terms of features and settings, and luban is like a baby version of cura (based on the same code)
