Hello
Is there any way to change the scale properties from Percentage to mm??
Not in Luban, no. It’s meant to be very simple and easy to learn.
Cura is essentially the same as Luban’s 3D printing tool, and does support scale by % or measurement. It even has profiles for the v2 hardware now, so it’s pretty easy to migrate to.
Luban will show the size of the object on the lower right and you can figure out the percentage by trying different values.
