Saved projects don't recall important information V 4.11.0
It’s really not acceptable that when recalling a saved project some very important information is not saved. Some I have noticed are: Position on the bed, orientation, print speed, layer height, there are bound to be others such as supports on or off. You have to be very careful just hitting generate gcode and printing without checking carefully what settings are being used. I would have thought the whole idea of saving a project is that you can re call it and just hit generate Gcode and print, confident in the knowledge that you have printed this before.
Cheers,
David
Save the Gcode and no second generate Gcode is needed.
This problem really needs to be dealt with, not brushed under the carpet.
It’s one of the most basic functions of Luban, and it DOESN’T work.
What’s the point of a saved project (3DP) if it doesn’t recall the same situation as when you saved it?
The first time one saves the project it ignores all settings and model orientation.
If you open the project and repeat all the settings and model orientation and then save again it then seems to work.
Luban 4.13.0 before you ask.
