Run a boundry and too big
Hello i plan my job in lightburn . save .nc file and put to usb then from the artisan usb . it is in my machine . then i run a boundry and the pointer draws a huge boundry, eg work is 200mm x 250 mm and the pointer runs boundry as 280 mm x 330mm aprox. . when i had the 10w module it was all good but since upgrading to 40w everything is not right. i need to put a 400 x400mm sheet in the machine and the boundry will draw way too big but once i cut the job it is the right size , how ever if i have piece of wood close to the right size . it is so hard to lign so it cuts job on the wood..
but if i design basic pattern and txt in LUBAN the boundry and cut works sweet.
