Right Extruder Only
My apologies if I am missing something but is there a way to print with just the Right extruder. Everything I do seems to default to the Left
If you are using OrcaSlicer,right click the model and at the bottom of the pop up box, choose change filament.
Yeah, which slicer do you mean?
Yes, it is possible to print using only the right.
That is something you would control with the slicer. The J1 will use whatever extruder the gcode tells it to.
