Hello everyone,
So I need some help reducing the spindle speed on my snapmaker 2.0. I reduced it on the tool in fusion 360 before I exported the cnc file but for some reason when I get it on the machine it’s still going full speed at 12000rpm. If I reduce on the console thus slows down how fast the tool moves around not the spindle rpms. I need to slow it down as I’m milling something with high detail and I want a good finish on it. How can I slow it down?
Since you are using fusion360 and not standard soft, verify your output gcode, what speeds are in it?
So I edited the g code, changed s100 to s50 but when it comes up on the console it’s still going at 12000rpms - am I missing something?
Firmware 1.17.17? Updated for spindle too?
Yes, I did a hardware update last night
I’m fairly certain this might be another bug in the firmware, your best bet is to report it to snapmaker support Support Ticket Form
Or roll down the firmware to where it was working… But without letting support know, they won’t be able to fix it…
I use the p setting to change spindle rpm. For the life of me I don’t understand why this simple setting is not an option in settings. I have to export the gcode, scroll past the visual representation part of the code and set it manually in a text editor, save, import, connect, send to machine. Kind of a pain. It is a 10 base percentage not specific rpm. Would be nice to have in the parameters with a reference table showing percent to rpm.
Isn’t s for travel speed?
Interesting: When you post process in Fusion using the Generic Snapmaker post it ignores the spindle speed set in the tool path; set 6000rpm and output will still be M3 P100. If you use the post by Nuno Vaz Oliveira the output will be M3 P50.
I have yet to use fusion to create cnc gcodes I am using just Luban for now. Will make a mental note to watch for this when I finally try using fusion.
Hello Snapmaker Freunde,
Ich habe mir heute Morgen Mühe gemacht, die Geschwindigkeit des Fräsmotors zu messen. Links in der Tabelle die prozentualen Werte, die Sie über die Konsole eingeben können.
Der folgende Input muss „M3 P…“ und natürlich hinter P dem Wert erfolgen.
Auf der rechten Seite die Drehzahl habe ich mit dem Tachometer gemessen!
Das Touchpanel kann nur ab einem Wert von 50% verwendet werden, was etwas mehr als 6000 U/min entspricht.
Leider können Sie nicht die Geschwindigkeit von Luban herraus festlegen, was möglicherweise etwas für ein Update in den Einstellungen des Cutters wäre und so, dass Sie dort auch die Geschwindigkeit dort festlegen könnten, wenn nur in Prozent, aber besser als überhaupt nicht!
P.S. Der Fräsmotor dreht sich so mit Geschwindigkeiten von 560 U/min bis 12350 U/min
