【Project Directory Summary !!】
If you have updates to your project in 【Projects,Tips&Mods】or other section,
you can post your thread link and project brief here (preferably with images).
Like this::backhand_index_pointing_down: :backhand_index_pointing_down: :backhand_index_pointing_down:
U1 Top-Cover Mod - U1 Toolchanger - Snapmaker: where creation happens
  • I designed a more aesthetically pleasing top cover for the U1. You can customize the color scheme, personalize your own nameplate, and it features a magnetic flip-open lid.
  • It mainly uses one type of self-tapping screw for easy installation, though the print time is quite long—it took me a whole week!!
New version of the Awesome List is online! @nweolu
Now with
  • Instant Search & Filtering: Find exactly what you need in seconds. Filter by your specific machine (Artisan, J1, SM2.0, Ray, etc.), toolhead type, material cost, or difficulty level!
  • Rich Resource Cards: Every resource now has its own detailed card with direct links, author credits, and specific tags, clean and easy to read.
  • Shareable Views: Dialed in the perfect filter combination? Click “Share Current View” to grab a custom URL that instantly loads your specific search parameters for whoever you send it to.
  • Favorites: Save the mods and tools you love to a personal favorites list directly in your browser.
  • Automated Submissions: I’ve built an automated issue-to-PR pipeline. Have a cool mod or guide to share? Use the “Submit a New Item” button, fill out the form, and our GitHub bots will automatically format the YAML and add it to the database for review.
Custom Firmware for Snapmaker U1 - Enhanced Features & WebRTC Camera @paxx12
Basic Firmware
  • SSH access ( and root/snapmakerlava/snapmaker)
  • USB ethernet adapter hot-plug support
  • Native camera integration with Fluidd
Extended Firmware
All basic features plus:
  • Hardware-accelerated camera (Rockchip MPP/VPU)
  • WebRTC low-latency streaming
  • USB camera support with hot-plug detection
  • Fluidd v1.35.0 with timelapse plugin (only ability to view timelapses from Web)
  • Dual camera support (internal + USB)
U1 Full-Spectrum Fork Gradient Generator Tool - U1 Tool Changer - Snapmaker: Where Creation Happens
Inspired by a post I saw on the Snapmaker subreddit the other day, I created a web app you can use to create custom color gradients for use with the Full-Spectrum Snapmaker Orca fork.
It lets you make smooth gradients using any kind of filament, to get results similar to ones you could get with rainbow filament (but with more control, as you can specify the exact start and end colors and speed). You can interpolate between as many colors as you like, and also use color mixes containing multiple filaments as nodes on the gradient.
If anyone would like to test it and give any feedback on how it works with real-life prints, that would be great, as I don’t have a U1 (only a single-color printer).
Here’s the link: https://gradients.garden
Hope this is useful to someone!
EDIT: You can now search for a filament name to import its color directly, courtesy of the colorimetry data from filamentcolors.xyz
Sidecar 16 color MMU for U1 - U1 Toolchanger - Snapmaker: where creation happens
[Tool] Bambu Lab to Snapmaker U1 .3mf Converter - Keep your color painting! - U1 Toolchanger - Snapmaker: where creation happens
Hey Snapmaker community !
I’ve built a free web tool that converts Bambu Lab .3mf projects to Snapmaker U1 format, preserving your multi-color painting work.
Link: https://bl2u1.nbn.cat
Off-line/self hosted version: GitHub - josuanbn/bl2u1: Bambulab Studio to Snapmaker Orca (for the U1) converter · GitHub
Note for experienced users: If you already understand the difference between importing geometry vs. opening a Bambu Lab project file directly (and the potential G-code issues), this tool is primarily a convenience for you. The main benefit is that it loads the model with the original color mapping intact, rather than defaulting to whatever filaments you currently have active in Snapmaker Orca.
What it does:
  • Converts Bambu Lab/Bambu Studio .3mf files to Snapmaker U1 compatible format
  • Applies the 0.20mm Standard print profile
  • Remaps colors and filament types to U1 compatible profiles
  • Automatically enables Tree Supports (auto) if the original model has supports enabled
  • Supports up to 4 filaments/colors
How to use:
  1. Upload your Bambu Lab .3mf file
  2. Adjust filament colors and types if needed
  3. Click “Convert and Download”
  4. Open the converted file in Snapmaker Orca for final slicing
Hope this helps someone else in the community!
Feedback and suggestions are welcome.
