Hello,
I am a new Snapmaker owner. In one of my first prints I noticed something about the figures, and I suddenly have an offset in the figure … Photo attached. What could it have there? Anyone have an idea?
That’s a layer shift.There have been many potential reasons reported for this to happen - here a few I’m aware of and waht to do:
The print sheet has moved while printing - most likely because the nozzle pushed on the print. Solution: use paper clips to fixate the print sheet, e.g. Heated Bed clips (set of 4) - Buy it now!
Errors in GCode/slicing. Solution: Use a different slicer like Cura or PrusaSlicer
Overheating of a linear module: The stepper controller chip has a silicon pad attached to it that dissipates the heat from the chip into the surrounding metal structure. There have been reports that in a linear module this pad was missing, causing the chip to overheat and temporarily lose function. This will cause missed steps on the stepper motor. Solution: Contact Snapmaker Support.
Going too fast - if you drive the print head at too much speed (too much starts somewhere at 150-200 mm/s or so - different opinions on that however), the stepper motor might miss teps also. Solution: print slower.
There may be more things - anyone with more suggestions?
And always a good source for information is here: Layer Shifting
