For some reason during printing in my artisan, the print layers shift by a lot after a few layers, and the print gets ruined. What could be a reason for this?
It could be code or mechanical. I am guessing the shift is in the X axis. Rotate your print 90 degrees. and print again. If it is mechanical the shift should still be in the X axis. For mechanical clean and re-grease the linear module screw. If the shift moves to the y axis look at the file, slicer and code.
Share your slicer, slicer settings, speeds and so on, please.
Was there a solution to this? I am having this issue no matter which slicer I use. Just started randomly 2 days ago with nothing noticeably different in my slicers’ settings.
I did follow the troubleshooting guide on the wiki which has me switch to shorter mounting screws. It helped but has not fully alleviated the issue.
This is only happening on my X-axis, I rotated my print in slicer 90 degrees and still confirm it is just X-axis.
https://wiki.snapmaker.com/en/snapmaker_artisan/troubleshooting/x_axis_unable_to_home
