Precise cutting coordinates
Hello,
I have to cut a lot of parts from MDF sheets.
I try to optimize my cuts to limit my waste and I use deepnest which provides almost full sheets to cut.
Now I have another dilemma: How can I place my sheets (which have little or no margin) so that the laser does not go out of the working area?
Camera shot gives good results if it’s perfectly calibrated, but it’s not enough, there are still a few millimeters difference and in my case I don’t have those millimeters since my cuts goes from edge to edge.
What solutions do you use to have as much precision when laying as when cutting?
You can use my repeatable laser origin guide.
There’s a sticky at the top of the 2.0 section with a bunch of guides. My whole goal is precision.
