My U1 is in my house downstairs and at the moment I can’t run it overnight as its too loud and can be heard in the bedrooms (Ikea lid mod & room door shut)
If I reduce the speed to 50% via the control panel it only stays like it until the next change of toolhead, thus would be nice to have a true NightMode/QuietMode whatever you’d like to call it where once set will stay like it until you change it again or the plate finishes printing.
So an example I start a 24hr print in the morning, at bed time I switch to the new mode & when I get up the next day I switch it back to normal mode to finish the print
I’ve voted for this not specifically for “night mode” but because it makes no sense for on-the-fly control panel settings changes to get overridden the next time there is a G-Code command. This does not only apply to print speed, it also applies to temperatures, fans (and perhaps other things I haven’t thought of).
Changes expressed in percent should apply until the end of the print (unless the user changes them again), and perhaps even until a new file gets loaded (so a reprint uses the existing settings).
Typically temperatures are set as an absolute value, but it is appropriate that temperature is controlled in G-Code – so make those an adjustment of so many ºC up or down from the command value when a print is in progress.
I would very much like this as well for similar reasons, all my printers are in the same area where I sleep so having them automatically slow down and go into dark/quiet mode during certain hours every night would be very nice indeed.
I’ve found that you can significantly reduce the noise just by lowering the idle speed—for example, from 500 to 250. No other adjustments are needed.
