I am finding when I pause a laser Job and then resume the X,Y origin changes. This trashes the print job. This also happens when I open the enclosure door. Both causes are intermittent. Anyone have a solution to this problem?
I’m not sure if it is the same problem or related: When I use Lightburn to generate GCode, it creates Code that uses relative positioning. When I pause such a job, the machine “forgets” about that and switches to absolute positioning, which causes all movements to center around the origin. I never looked if I can switch to absolute positioning, I just do no longer pause the jobs ![]()
But if in your case your origin moves but the movements continue as expected otherwise, or you use Luban, then it is most likely a different problem, and I’d contact support on that.
