I have two machines, both the same, one labelled A350T and my new F350. I have unboxed and assembled fine.
Probably not related - On power up reported module needed software update all completed fine.
When I try and calibrate the print head descends and actually presses so hard on mat it’s marked it and I had to power off and manually raise the axis. I guessed the proximity sensor and indeed can’t make out the red light. As I had the older machine next to it I swapped print heads and all calibrated as normal. Does this mean I need to request support or is there a simpler troubleshooting guide to follow?
Jem
Double check the height of the proximity sensor on the other toolhead. There’s a small screw in a slot on the back to adjust the depth, it should be about 0.5-1mm higher than the tip of the nozzle.
When the machine is booted, try bringing a small metal object to the sensor to see if the red light comes on. Test both and maybe make a video. If one lights up, and the other doesn’t, the proximity sensor is likely a dud. Contact support@snapmaker.com and they should provide a replacement. However, they’re currently off on lunar new year so response will take some time, sometime at the beginning of February.
Thank you. I have measured the proximity sensor level with a flat edge and it does look about 1mm above nozzle and more or less the same as my old machine.
Can I ask you to clarify what you mean by test both. I have tried using a non metallic surface below the print head when I tried to calibrate but couldn’t see the light on the sensor. Is there two?
The material has to be metallic. It’s an inductive sensor and reads the metal print sheet. I meant test both of the print heads on the same machine, power cycling between them. Try touching a screwdriver to the bottom of the probe to activate it.
Yes thanks, I have that all correct. As you can see from the conversation above the machine calibrates just fine with my other print head so at least I’m sure it’s a problem with the print head assembly. I’m suspecting the proximity sensor but I suppose it could be the circuit board.
