Could someone get me a measurement of the inside of the filament carrier hub from the snapmaker filament that came with the machine? In MM please. I am wanting to print out a hub adapter, but my digital calipers haven’t arrived. Appreciate the help.
If you mean the inside diameter of the hole of an original Snapmaker filament roll, it is close to 53,5 mm (measurements were between 53,4 and 53,8 mm, mostly around 53 and a half). I had an empty one going to the trash bin, but asked in time…
Kaitzu
Thank you. Appreciate the help.
Hello,
i have createt a Model that can Use with any Coils.
Spulenhalter Teil 2.stl (358.8 KB)
Spulenhalter Teil 1.stl (719.3 KB)
Thank you. I will give a try.
