Hi guys, this is the first project…
in this project i had some warping problem, how can i solve this? With a Brim?
on the top surface are visible zebra effect like in the photo, how can i attenuate it?
I can very much recommend this: Print Quality Guide | Simplify3D Software It helps with a lot of problems you might encounter, among this warping. Indeed Brim is a good idea, also temperature control. The Zebra-effect can to some extent be countered by ironing - that’s at least the “theory” personally I never tried it, because I accepted this look as OK ![]()
what software did you use to create the 3D model? Luban?
@sciss No, Luban is only a slicing software. To create a 3D model you need CAD software, such as Fusion360, TinkerCAD, etc.
Blender…Luban is not a software of 3d modeling.
