I have an S2 A350 and I’ve successfully completed the CNC tutorial.
Next I want to do a two-pass bas-relief carve. The first pass should do a rough cut and the second pass would do the detail with a v-bit and small step distances.
I can see how to specify multiple processes in Luban, but the running time for the second pass makes me think that Luban is not taking advantage of the rough cut to save time for the detail cut, which is the whole point of doing two passes like that.
Can Luban do what I want, or do I need to dive into Fusion 360?
In either case, I hope someone can share a short description or link to a tutorial about how to do two-pass rough+fine CNC milling.
Thank you!
