Mouse ears instead of raft - possible in Luban?
Hi everyone,
maybe i am blind, but i can’t find a way to add mouse ears only instead of a full raft to my objects to print.
Any suggestion to do it (beside using a different slicer :slight_smile: )
I know this only from prusa slicer and even can’t find it in Luban.
As workaround you could import a model like your desired “Mouse ear” and bring it in place where you want it to be.
Its not the most elegant solution but still works:
Sorry for the smiley form, its a chip for shopping carts :wink:
If you like, open a feature request but as Luban is based on Cura I guess Cura needs the feature first.
Thanks for your reply.
I’ve seen that for Cura there was a plugin available via Marketplace. But they obviously removed it, it’s not any longer available for the original Cura version.
So i doubt it will be in Luban at a later point.
Meanwhile for those objects where a mouse ear is required i am using Orca Slicer (fork of a different slicer) which offers mouse ear support.
Orca was my favorite slicer before i moved to the Artisan, but there the printer wasn’t supported - until now where the latest version has the Artisan in.
