Every time I 3D print a project, Luban outlines the project with a single trace (border line) which has to be removed manually when the printing is done. I see no use of printing that line in the first place. Is there a way of telling Luban to not print a boarder line?
It’s called a skirt.
Most people find it useful to help ‘prime’ the extruder and get stuff flowing. It’s also a way to check the z-offset before it starts actually printing.
If you turn off skirt (set to 0?) it won’t print it.
If you’re having trouble removing it, set it to 3 and then it’s easier to remove.
_S
