Hello everyone,
A few weeks ago, I purchased the Snapmaker Ray and, after some initial difficulties, I’m fairly satisfied with it. Unfortunately, the door sensor sometimes doesn’t work properly. The laser moves, but it intermittently stops cutting/engraving. I use Lightburn, which generally works flawlessly, but to disable the sensor, I need to access the laser with Luban.
Now, the major issue: Luban recognizes that the laser is connected at COM4, as well as COM5 and COM6, but it doesn’t connect to the laser.
I’ve already updated the driver, and once, when it briefly worked, I also updated the laser. I keep Luban up-to-date, but it still won’t connect.
What could be the cause of this?
Thanks in advance!
