Luban 4.0.0 won't turn the laser to 100%
I know the problem: if you start the job from luban (to use the camshot feature) the settings in the toolpath are not used. Check out my screenshot.
Unfortunately I have not yet found a solution that the Snapmaker uses the settings of the toolpath. If you export the G Code and send it to the Snapmaker, the settings are used. But in that case you have to set the work origin over the devise and can’t use the cam capture.
