Luban 3.8.0 Won't Close
After upgrading to Luban 3.8.0 it does not want to close. I’ve tried the
Clicking on the “X”,
Clicking on the Menu under Window => Close
Clicking on the Window icon => Close
Not of these options will close the window.
Which OS do you run? I had no problem under Win10…
Windows 10 as well.
Edition Windows 10 Pro
Version 20H2
Installed on ‎4/‎18/‎2020
OS build 19042.423
Serial number 005113474657
Experience Windows Feature Experience Pack 120.2212.31.0
I have tried again, no problem found.- May re-Install Luban to double check?
Where did you get this nice overview of the win-version from?
Right Click on “This Pc” icon on the Desktop
Click on “Properties”
Scroll Down to “Windows Specifications”
Highlight and copy.
I have identified the problem. In a previous installation there was an issue where luban would not save the current window location and size. A temporary fix was to make the config.json file readonly after making manual changes. This temporary fix is the culprit preventing the app from closing. After removing the readonly flag on the config file it is working correctly now.
