Hello, today I found a loose screw in the enclosure of my Snapmaker 2.0. I then noticed that this screw came from the bracing kit and that a few other screws were about to fall out. My question now is how far I should tighten these screws, as the quick start guide for the bracing kit says that you shouldn’t tighten these screws.
I accidentally tightened them at assembling and loosened it compared with another.
It needs to be as loose as the bracing kit has enough space at the end of the rail for the spring, I guess about 0.5 to 1 count loose.
