Layer Shifting problems
Is it ok that I share my layer shifting problem here as well?
Sure. It’s within the same realm.
This thread is very helpful. I attempted my first 5 hours print last night and it experienced the layer shift in the last cm or so of the print.
I have solved this issue on other printers but there are no belts or pulleys to adjust here.
I slice with S3D and did not see an G code issues. It’s a 7mb file so I’m going to spare the upload :slight_smile:
My print speeds are 60mm/s and less so no issues there.
I suspect either overheat or the printhead clipped the part. I am going to enable z-hop of .5 as you suggested and try again. Perhaps I will decrease the speed to 40/mms as well.
Having the same issue for the first time. Using latest Luban, 3.13.1 and default slicing for “Fast” (aka low fill) print. Using latest firmware as well.
Overextrusion is causing the nozzle to push against a wave of filament from the below layer, causing the skipping.
Also the first layer looks underextruded in parts.
  1. Fix the calibration so the first layer is more consistent
  2. Then correct the overextrusion
I had an issue with layer shifting today, and when I investigated, I found it was due to the linear modules needing cleaning.
After ~2 years of sitting on my desk, enough dust, grit etc. had got into the modules that it was hard for me to back-drive them (when powered off). I sprayed some WD-40 White Lithium onto the lead screws, and it freed them back up.
It also stopped a horrible rubbing noise that had started occuring.
I too am having the same issue with the shift in my project. I’ve printed it twice and the error happens in the same location. I’ve reviewed my Gcode through a view online and didn’t see the issue.
Has anyone solved this issue?
Judging from your image @crosswindjones uses a SM2 - I think this thread is on Snapmaker Original. There are several threads on layer shifts on SM2 with various causes and solutions - I recommend to enter “layer shift” into the search box and pick the topics for SM2, there’s helpful advice!
