I am trying to isolation route a PCB and imported a dxf. If I set the toolpath to “along the path” g-code is generated normally, but if it is set to any form of fill no g-code is generated at all. The upload doesn’t support dxf files so I can’t put my file up here but I have screenshots of the work window and preview below *I have removed the blank preview image because new users can only have one image pasted into a post*. I have tested and my Artisan does nothing with the file if I try to run the engraving process. As a new user I cannot upload attachments, so generated g-code is pasted to the bottom of this post.
;Header Start
;header_type: laser
;tool_head: 2W Laser Module
;machine: A400
;gcode_flavor: marlin
;renderMethod: point
;max_power: 255
;file_total_lines: 72
;estimated_time(s): 0
;is_rotate: false
;diameter: 0
;max_x(mm): 31.999
;max_y(mm): 30.999
;max_z(mm): 0
;max_b(mm): 0
;min_x(mm): 31.999
;min_y(mm): 30.999
;min_b(mm): 0
;min_z(mm): 0
;work_speed(mm/minute): 500
;jog_speed(mm/minute): 8000
;power(%): 100
;work_size_x: 400
;work_size_y: 400
;origin: bottom-left
;thumbnail: data:image/png;base64,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
M2003
M2004
;Header End
;Snapmaker Luban 4.15.0
;Fri May 15 2026 15:19:9
M2000 L30 P0
G4S5; Laser multi-pass, pass 1 with Z = 0
; G-code for laser engraving
; Generated by Snapmaker Luban
; G-code START <<<
G90
G21
M2000 W1 P100
M2000 W2 P100
M3 S0
M9
M2000 L23 P1
G0 F8000
G1 F500
G0 X32.00 Y31.00
M5 S0
; G-code END <<<
; Laser multi-pass, pass 2 with Z = 0
; Laser multi-pass: dropping z
G91
G0 Z-0 F150
G90
; G-code START <<<
G90
G21
M2000 W1 P100
M2000 W2 P100
M3 S0
M9
M2000 L23 P1
G0 F8000
G1 F500
G0 X32.00 Y31.00
M5 S0
; G-code END <<<
G91
G0 Z0 F150
G90
