I found when testing small images 50x50mm, I could do 4 easily on the one piece of 150gsm white card, which was my test bed. Ir was easy to do the first print to the front left corner of the platform.
When complete I could turn on the laser Focus again and re-position the beam to the right side of the first image, reset the origin and run the second print and so forth, move the beam further back above the first image set the focus. I could easily print 4 images on the one card.
BTW if you use ordinary 80gsm paper you are likely to burn holes through it depending on how much the laser dwells in the one spot and what power level you are using. That is why I tried 150gsm card.
Despite my terrible photography the greyscale image came out like a photo. As mentioned earlier I am yet to try wood, leather or acrylic materials.
Algorithm: Stucki
Dwell: 30
Laser Power: 90% ((note this applies to my Snapmaker and I understand it varies between Snapmakers)
The image size was 50x62mm
I would like to buy a Snapmaker to print QR-Codes on Key-Chains. The material will be leather and it will have a size of 2x2 cm. Does the laser engraving have a high enough quality so that it will be possible to scan the QR-code with a smartphone?
I am thankful for any kind of experience you can share.
@jan_ka
I’m pretty sure this will work when you are able to do this with an ink jet printer (of course on paper)!
Currently I’m in 2 print jobs (I have 2 Snapmakers) but I will make a test for you on wood when you send me the file.
Hello Team,
this is really great collaboration. Looks super good.
One last question: Did one of you ever print on leather? Is the quality like on wood?
Best,
Jan
Laser engraving, which is a subset of laser marking, is the practice of using lasers to engrave an object. The impact of laser marking has been more pronounced for specially designed “laserable” materials and also for some paints. These include laser-sensitive polymers and novel metal alloys.
