Still learning the process for laser engraving, very new to this. I have the image pulled up in Luban, I have Greyscale selected. I’ve also select Sierra-3 as my preferred algorithm but once I hit process this is where i get lost.
I understand from the Guide that 1500mm/min is the recommended jog speed but a / is used for the work speed and I have no idea what that means. I had someone suggest that just means 1500 work speed but all settings I see tell me that may not be the case.
I’m using a 3mm piece of plywood.
If someone could give me some pointers that would be much appreciated.
