Hi all,
I bought Pine wood (5mm) to engrave some pictures. Looking at the start guide, I don’t see the size the wood should be. Engraving is 12,5x12,5cm but how much I have to cut the wood
thank you
Hi all,
thank you
Same, depending if you need to fix it.
At the start of the original the engraving size was limited to, I guess, 80mm.
