Any help? I’m cutting very thin (6mm) foam that is 12x24 inches but I want it in one piece. It cuts beautifully but Luban cuts the piece in half, at the back edge of the cutting platform. There is no blue line on the back edge of the cutting platform so I’m not sure how it’s getting the info to cut there.
I’m looking for a way to cut half of the item, then reposition the foam for the second part, leaving it all in one piece.
Thanks
I would recommend the software called Lightburn. This would be trivially easy through this software. I have done piece much longer that my print bed (four separate chunks!) and it turned out beautifully with nothing to point to it being done in separate sections.
If you’re planning on doing any amount of lasering, I reckon this’ll make your life much easier.
