The some of the keyboard shortcuts no longer work with the latest Luban and Firmware updates. I can PgUP and PgDwn to control the tool head height, but the arrow keys don’t work.
File Commands
|Command|Keyboard Shortcut|
|New|Ctrl+N
|Open|Ctrl+O|
|Save|Ctrl+S|
|Save As|Ctrl+Shift+S|
|Import|Ctrl+I|
|Export|Ctrl+E|
Main Commands
|Undo|Ctrl+Z|
|Redo|Ctrl+Shift+Z|
|Select|Left-click|
|Multi-Select|Shift + Left-click|
|Select All|Ctrl+A|
|Copy|Ctrl+C|
|Paste|Ctrl+V|
|Part Placement|Select part, left click and drag to transform|
|Delete|Back / Delete|
Those are not the shortcuts I was referring too. The keyboard shortcuts below don’t work.
but…in that capture, it seems that the shorcuts are turned off? try clicking that switch at the left of the k in keyboard?
That’s because I took a screen shot from my desktop computer not attached to the machine. I have connected via both serial and wifi with the shortcut button toggled and it doesn’t work. Eitherway…The firmware or Luban updates has affected the snapmaker 2.0 jog commands. As I mentioned in the first post, the pgup and pgdwn button to jog the toolhead up and down still work. The arrow keys don’t work as they did in the past.
