Implement Filament Auto Mapping For Prints Initiated From Fluidd
Out of sheer laziness, I clicked “print” in Fluidd instead of walking into another room and starting the print on the U1 control panel. If I had used the control panel, the U1 would have picked up that I wanted black PETG for the model and white PLA for support, and automatically assigned the appropriate tool-heads.
From Fluidd, it just used T0 and T1 without mapping them.
Edit: The next post (Zoe_M) confirms this is expected, and undesirable. Moved to Feature Requests.
Hi, I have checked with the firmware development team, and this is indeed a known behavioural limitation in the current official firmware. The official Moonraker API does not integrate this U1‑specific pre‑processing logic for automatic filament mapping.
Our development team has added this request to the feature backlog for future evaluation.
You may consider editing this topic and moving it to the feature‑request category.
Best regards.
Done.
I can’t believe nobody else wants this sorted out!
I fell foul of it again, from the Orca “Print” button this time (which I presume is the same problem).
orca print starting it straight through moonraker would explain it iirc, file just runs with the Ts already in it
