I keep getting this error when sending a file to the printer: error code: 0001 0531 0000 0015 print task config not allowed to set extruder map during printing
I keep getting this error when sending a file to the printer: error code: 0001 0531 0000 0015 print task config not allowed to set extruder map during printing. There is no way to bypass this. Any suggestions?
Are you printing?
Cannot get passed the error message, happens when sending the file to the printer.
Maybe hit “Send to machine” instead of “send and print” :thinking:.
What file is it?
Is it one specific file or every file? Is it a print from Snapmaker Orca, or somewhere else? It seems likely to be an error in the data, the question being where the error came from.
I am getting the same issue, same code. Did you get a fix yet?
