When using octoprint (on RPI 3B+) the exported G-code (from Luban or Cura) let the extruders run into each other. For example: a print with PETG as support (right extruder) and PLA for the object (left extruder). When the right extruder printed the first layer it stops moving and stays at the last print position above the printbed, when in should have moved out of the way to the oozing shield (all the way to the right of the printbed). When the left extruder moves in to the printbed in runs into the rightextruder and prints in the wrong place.
Using the G-code directly from luban to the Snapmaker J1 results in correct moving and printing.
What do I have to do to print ‘normally’ via Octoprint with my IDEX machine?
1 other question: What is the safest en eadiest way to enable Host action commands?
What did you already try to solve it?
I read some fora about the same problem and using M605 S1 as standard G-code before the start of a printjob did not fix it.
Have you tried running in safe mode?
Yes
Did running in [safe mode] solve the problem?
No
Systeminfo Bundle
You can download this in OctoPrint’s System Information dialog … no bundle, no support!)
I am not able to upload the system bundle, because I am a new user.
Additional information about your setup
OctoPrint version, OctoPi version, printer, firmware, browser, operating system, … as much data as possible
OctoPrint version 1.10.2
OctoPi version 1.0
Snapmaker J1
Marlin
Chrome
Windows 10
Luban (or Cura)
