The lastest version of firmware and Luban are installed. Luban terminal is communicating with the A350 (single extruder, no other accesories) via USB serial port (COM 6), not Wifi.
I read some posts here on the forum about calibration and folks wrote about how to do that using the Teaching Tech web-site. I got a value for acceleration and want to save that in the SM2 EEPROM.
I type M204 to get the accelaration value:
M204
ok
T:26.40 /0.00 B:20.62 /0.00 T0:26.40 /0.00 T1:0.00 /0.00 @:0 B@:0 @0:0 @1:0
ok
others < Acceleration: P1000.00 R1000.00 T1000.00
I change the value of acceleration:
M204 P750
M204 P750
ok
ok
I check that value has changed
M204
M204
ok
others < Acceleration: P750.00 R1000.00 T1000.00
ok
I save to EEPROM using M500
M500
M500
ok
echo:Settings Stored (1186 bytes; crc 854)
ok
I cycle the power, and check the settings:
M204
M204
ok
ok
P is back to the default. According to Marlin site, M204 settings are stored using M500.
Where am I going wrong?
Is 750 out of range?
Do I have to connect to the printer via USB to set acceleration each time prior to printing?
Is acceleration no longer required to be calibrated?
Have the developers disabled that function?
