Hello All,
Thanks in advance for your assistance. I’ve been working on this issue for 3 days with no success. To create my first 3D print I decided on a simple VW car model (https://pinshape.com/items/33138-3d-printed-volkswagen-golf-gti-low-poly-miniature).
I created a gcode and have been playing with the settings for the last 3 days and no matter what I a do I end up with this:
I tried:
Reducing extrusion flow from 100% to 75%
Enabling retraction
Reducing infill Speed
Enabled a reasonable sized brim
Set infill Density to 70%
Reduced layer height
Increased layer line width
Among other things.
Here are my print settings (copy and paste to “def.json” file to view, as I’m not allow to attached files yet):
{“version”:1,“name”:“Original-Normal Quality”,“inherits”:“snapmaker”,“metadata”:{“visible”:true,“readonly”:false,“author”:“walker”,“manufacturer”:“Snapmaker”,“file_formats”:“text/x-gcode”,“machine_extruder_trains”:{“0”:“snapmaker_extruder_0”}},“overrides”:{“layer_height”:{“default_value”:0.15},“layer_height_0”:{“default_value”:0.2},“initial_layer_line_width_factor”:{“default_value”:120},“wall_thickness”:{“default_value”:0.8},“wall_line_count”:{“default_value”:2},“top_thickness”:{“default_value”:1},“top_layers”:{“default_value”:7},“bottom_thickness”:{“default_value”:0.6},“bottom_layers”:{“default_value”:4},“infill_line_distance”:{“default_value”:1.1428571428571428},“infill_sparse_density”:{“default_value”:70},“retraction_enable”:{“default_value”:true},“retraction_speed”:{“default_value”:50},“retraction_amount”:{“default_value”:6.5},“retract_at_layer_change”:{“default_value”:false},“speed_travel”:{“default_value”:45},“speed_topbottom”:{“default_value”:30},“speed_wall_x”:{“default_value”:25},“speed_wall_0”:{“default_value”:25},“speed_wall”:{“default_value”:30},“speed_infill”:{“default_value”:15},“speed_print_layer_0”:{“default_value”:15},“speed_travel_layer_0”:{“default_value”:30},“skirt_brim_speed”:{“default_value”:15},“retraction_hop”:{“default_value”:1},“retraction_hop_enabled”:{“default_value”:false},“magic_spiralize”:{“default_value”:false},“magic_mesh_surface_mode”:{“default_value”:“normal”},“adhesion_type”:{“default_value”:“brim”},“skirt_line_count”:{“default_value”:1},“brim_width”:{“default_value”:8},“brim_line_count”:{“default_value”:10},“raft_margin”:{“default_value”:15},“support_enable”:{“default_value”:false},“support_type”:{“default_value”:“everywhere”},“support_pattern”:{“default_value”:“zigzag”},“support_angle”:{“default_value”:50},“support_infill_rate”:{“default_value”:15},“support_line_distance”:{“default_value”:2.66},“support_initial_layer_line_distance”:{“default_value”:2.66},“speed_print”:{“default_value”:60}}}
Any help will be greatly appreciated.
