Hotend will not heat up
So while cleaning out a clog from a stupid I committed, I accidentally pulled out the two little wires from the heatbreak. I tried sliding them back in as far as I could, but it still won’t heat up. Is there a way to save this?
I’m currently not in a position to buy a replacement part.
Picture? There’s four wires and there’s multiple places that it could have slid out of. But yeah as long as the four pins in the connector are all in, and the wires are not touching each other (shorted out) and the touch screen is reading a reasonable temperature then it should work.
Also replacement hot end is inexpensive and there should be one in your toolbox unless you’ve used it already
